platini76
Aug 22, 2013Aspirant
READYNAS PRO4 wake on lan mac osx
hallo friends, one question: it is possible to use raidar widget as wake on lan on a readynas pro? or there is another mac osx widget? thanks davide
Aug 23, 2013Guru - Experienced User
As I said, you'd have to shut the pro down, as you can't put it to sleep. It is possible to construct a curl script to do that (as your links suggest), or you can simply use frontview.
