Bernhard_Hartl
May 27, 2013Aspirant
ReadyNas PRO6 hangs when BulkCopy
Hello when I copy a huge amount of data or files (e.g. VMWare Images or photos) to my readynas pro it often hangs and goes on copying this files after a while (about 1Minute delay) - JumboFrames a...
Bernhard_Hartl
May 30, 2013Aspirant
chirpa wrote: The smbd.log in your System Log zip does not have enough history in it to get an idea of possible errors. Best thing I can suggest is next time it happens, get the logs right away.
Have reproduced the Hang on my Backup-machine that is still quite full
Something leads to broken pipes
see the SMBD-log snipset below
On my main NAS the problem is gone since I have the diskload down to 50%
thank you
Bernhard
[2013/05/30 10:13:25, 0] smbd/server.c:1143(main)
smbd version 3.5.21 started.
Copyright Andrew Tridgell and the Samba Team 1992-2010
[2013/05/30 10:19:13.362992, 2] auth/auth.c:314(check_ntlm_password)
check_ntlm_password: Authentication for user [Bernhard] -> [Bernhard] FAILED with error NT_STATUS_NO_SUCH_USER
[2013/05/30 11:10:49.524984, 2] auth/auth.c:314(check_ntlm_password)
[2013/05/30 11:12:43.558067, 0] lib/util_sock.c:680(write_data)
[2013/05/30 11:12:43.558189, 0] lib/util_sock.c:1441(get_peer_addr_internal)
getpeername failed. Error was Transport endpoint is not connected
write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
[2013/05/30 11:12:43.558232, 0] smbd/process.c:79(srv_send_smb)
Error writing 51 bytes to client. -1. (Transport endpoint is not connected)
[2013/05/30 11:12:43.558438, 0] lib/util_sock.c:680(write_data)
[2013/05/30 11:12:43.558472, 0] lib/util_sock.c:1441(get_peer_addr_internal)
write_data: write failure in writing to client 0.0.0.0. Error Broken pipe
[2013/05/30 11:12:43.558514, 0] smbd/process.c:79(srv_send_smb)
Error writing 104 bytes to client. -1. (Transport endpoint is not connected)
[2013/05/30 11:12:43.558806, 0] lib/util_sock.c:680(write_data)
[2013/05/30 11:12:43.558862, 0] lib/util_sock.c:1441(get_peer_addr_internal)
[2013/05/30 11:12:43.558894, 0] smbd/process.c:79(srv_send_smb)
[2013/05/30 11:12:43.559112, 0] lib/util_sock.c:680(write_data)
[2013/05/30 11:12:43.559156, 0] lib/util_sock.c:1441(get_peer_addr_internal)
[2013/05/30 11:12:43.559188, 0] smbd/process.c:79(srv_send_smb)
[2013/05/30 11:12:43.559360, 0] lib/util_sock.c:680(write_data)
[2013/05/30 11:12:43.559394, 0] lib/util_sock.c:1441(get_peer_addr_internal)
[2013/05/30 11:12:43.559424, 0] smbd/process.c:79(srv_send_smb)
[2013/05/30 11:12:43.559553, 0] lib/util_sock.c:680(write_data)
[2013/05/30 11:12:43.559586, 0] lib/util_sock.c:1441(get_peer_addr_internal)
[2013/05/30 11:12:43.559630, 0] smbd/process.c:79(srv_send_smb)
[2013/05/30 11:12:43.559780, 0] lib/util_sock.c:680(write_data)
[2013/05/30 11:12:43.559810, 0] lib/util_sock.c:1441(get_peer_addr_internal)
[2013/05/30 11:12:43.559839, 0] smbd/process.c:79(srv_send_smb)
[2013/05/30 11:12:43.560000, 0] lib/util_sock.c:680(write_data)
[2013/05/30 11:12:43.560046, 0] lib/util_sock.c:1441(get_peer_addr_internal)
[2013/05/30 11:12:43.560123, 0] smbd/process.c:79(srv_send_smb)
http://www.bernhard-hartl.com/Share/System_log-NAS2-20130530-111304.zip
