Bernhard_Hartl
May 27, 2013Aspirant
ReadyNas PRO6 hangs when BulkCopy
Hello when I copy a huge amount of data or files (e.g. VMWare Images or photos) to my readynas pro it often hangs and goes on copying this files after a while (about 1Minute delay) - JumboFrames a...
TomMDS
Jul 25, 2013Aspirant
Strictly to do with Samba / CIFS per your messages. I've stumbled on this earlier myself and do notice that the IP it's trying to get to is 0.0.0.0 which could indicate a downed NIC. Hence why a restart probably worked for me (having documented this)
The same issue documented here:
http://microdevsys.com/wp/error-writing-bytes-to-client-transport-endpoint-is-not-connected/
Then with Samba / CIFS look into some of the issues here for debugging tips and scanning on your network:
http://microdevsys.com/wp/networking-sharing-folders-between-windows-and-linux-using-samba/3/
I remember running into this when the NIC card chip was broken (82574L) and couldn't handle the traffic. Try a search on the above pages for that as well. Hopefully this moves you along further.
