SWolfer
Mar 12, 2023Aspirant
ReadyNAS Raid 10 Volume Disappeared
Hi I am running a RAID 10 (4 4TB Disks) on a ReadyNAS G214. One of the disks failed. The remaining 3 disks are all fine. The NAS ran in degraded mode while I awaited a new disk. Before the disk ...
Sandshark
Mar 12, 2023Sensei
The drives are not in a format accessible by a Windows PC, so that's not going to work. Can you get into the GUI at all? If so, what message(s) do you see with regard to the volume? How about in RAIDar? Are you comfortable using SSH and the Linux command line (as fixing it may require you use it)?
That the "Goodbye" message stays up and the NAS does not actually turn off seems to be saying something. Typically, it will end up showing something else, so I'm unsure what that means. But it seems likely something in the OS is corrupt. Maybe a hardware issue, but I'm not convinced at this point.
Can you access the boot menu? If you can, try booting in read-only mode with each set of two drives in case the issue is just with yet another drive. If it does boot, then get your backup in order and then try a standard boot.
A simple OS re-install may be in order, but I'd hold off on that until you provide more details and we can see if it seems appropriate.
SWolfer
Thank you
I ended cutting the power and it auto-restarted when I plugged it in.
Not sure how to boot in read-only mode, but it booted up fine and I can access it through the GUI. This is what it shows:
The OS seems fine. It seems to be that it lost the volume pointers.
Thanks again for your help and please let me know what else you might need
- SandsharkMar 13, 2023Sensei
You boot in read-only mode via the boot menu. See How-do-I-access-the-boot-menu-on-my-ReadyNAS-102-202-212-or-312 . The reason for booting in read-only is to keep the drives from becoming more out of sync before you determine which ones work (if any combination does). At this point, I'd try the drives in bays 2 and 3 first.
If you can't get it to boot with a readable volume, it would be best if somebody reviews your log files to see what recovery method may work for you. You can't (and don't want to) post the log file here. You'll have to put it on a file sharing site (such as Dropbox or Google Drive) and ask a moderator or perhaps StephenB to review it. With recent changes in moderators here, I'm not sure who that would be. And I'm just not the right guy for it.
- StephenBMar 13, 2023Guru - Experienced User
SWolfer: Sandshark accidentally gave you the link for 2-bay NAS. Your RN214 instructions are different:
