SWolfer
Mar 12, 2023Aspirant
ReadyNAS Raid 10 Volume Disappeared
Hi I am running a RAID 10 (4 4TB Disks) on a ReadyNAS G214. One of the disks failed. The remaining 3 disks are all fine. The NAS ran in degraded mode while I awaited a new disk. Before the disk ...
Mar 14, 2023Guru - Experienced User
SWolfer wrote:
OK, did the restart into read-only boot and sent the logs
I should have also said to remove the 8 TB exos while the NAS was powered down. It's generating a flood of error messages, and isn't even showing up in disk_info.log.
Then boot up, and send me new logs.
FWIW, this isn't looking good. I think you will likely need to try RAID recovery software (like ReclaiMe) - which would also require getting suitable USB dock(s) to connect the disks to a windows PC.
SWolfer
Mar 14, 2023Aspirant
The 8TB disk is not in the NAS
There are 4 4TB disks in, with the disk in slot 1 being the failed disk
Should I remove the failed disk and restart?
- StephenBMar 14, 2023Guru - Experienced User
Yes. Then send new logs. My hope (perhaps not likely) is that the NAS will attempt to mount the data volume with it removed.
There's other things going on with the OS partition and the swap partition (also on the disks) which might resolve if the failed disk is removed.
