SuperNASman
Feb 08, 2014Aspirant
Readynas Remote Using Public RIPE IP Address
The reason I'm here is because of unstable connections to my readynas via Readynas Remote. After a little reading I find that the 5.x.x.x IP address is a public address assigned to RIPE. I believe ...
Feb 08, 2014Guru - Experienced User
Netgear should stop using the address range, but I don't think that is causing your connection issues via Remote. I think that is unreliability in the netgear cloud.
The main failure mode is that a system with the ReadyNAS remote client installed cannot reach the true 5.x.x.x addresses, because the remote VPN client will route traffic to those addresses to the the netgear servers instead.
