SuperNASman
Feb 08, 2014Aspirant
Readynas Remote Using Public RIPE IP Address
The reason I'm here is because of unstable connections to my readynas via Readynas Remote. After a little reading I find that the 5.x.x.x IP address is a public address assigned to RIPE. I believe ...
Feb 10, 2014Guru - Experienced User
I like the concept, though it would be more powerful if they had the software running on mobile devices too. Are you using the NAS as the supernode?
chirpa wrote: Ya, I saw this issue awhile ago with real Internet servers in 5.x address space. Remote becomes useless then, as it blocks all that traffic.
I use n2n (http://www.ntop.org/products/n2n/) now. Manual setup at first, but acts similar. Uses a 'supernode' like peerserver.netgear.com broker server. Then each 'edge' client uses that for initial connection, before going p2p to each host it wants to talk to. Added benefit of being actually stable, and lets me use my own true private IP ranges.
