razorbrades
Nov 13, 2012Follower
ReadyNAS remote with Android
I am trying to set up my ReadyNAS Duo so that the ReadyNAS Remote Android app can access it remotely. I am currently on RAIDiator 4.1.10. My problem is that when I activate ReadyNAS Remote on RAIDi...
verb14
Jul 07, 2013Aspirant
@mdgm, Thanks; tried it over the weekend but no luck - now I'm not even getting the share listing when I log in from the Android app - just a blank screen with the tabs - remote/local/gallery; will try again after rebooting the NAS and reinstalling the Android app.
BTW, any idea if I can re-register my 102 with ReadyCloud - had removed the user and cannot add again - searching with the serial number isn't helping either.
cheers...
cheers...
