KayZak
Nov 10, 2016Aspirant
ReadyNAS Replicate Job Returning "Connect error code: -51"
Hi All, (Please do not tell me to contact support. They are thoroughly unhelpful.) I recently purchased a second ReadyNAS RN102. Both ReadyNAS RN 102's are running on OS 6.6.0 and are on the ...
FramerV
Nov 11, 2016NETGEAR Employee Retired
Hi KayZak,
Here are some of the basic things to check.
Communication problems between NASes
Errors codes in Replicate portal logs. 50, 51, 122, 300, 501
- Check the Internet connectivity and service connectivity on both sides.
- ReadyNAS OS 6. ReadyNAS Remote should be enabled on both sides.
- For restrictive firewalls and more complex networks, consider setting up port forwarding. (port 6300).
- Remove Replicate user binding and re-add the NASes to the Replicate account. Then, recreate the backups. Use the “resume from…” option to avoid having to send all of the data again.
mdgm-ntgr
Nov 12, 2016NETGEAR Employee Retired
What does the initrd.log look like for each of your two systems?
- StephenBNov 15, 2016Guru - Experienced User
KayZak wrote:
mdgm-ntgr How would I look for that? I have SSH'ed into the system but I'm not familiar with linux systems, so if you could direct me with the path and commands to use to view this file, that would be excellent.
Download the log zip file from the web ui, it's in there.
- KayZakNov 16, 2016Aspirant
mdgm-ntgr
My most recently purchased ReadyNAS has:[2016/09/09 19:13:03] Factory default initiated by RAIDar (format used disks)!
[2016/09/09 19:13:06] Defaulting to X-RAID2 mode, RAID level 1
[2016/09/09 19:13:29] Factory default initiated on ReadyNASOS 6.0.8.
[2016/09/09 19:13:31] Factory default initiated by Frontview!
[2016/09/09 11:38:33] Updated from ReadyNASOS 6.0.8 () to 6.2.5 (ReadyNASOS).
[2016/09/09 11:51:24] Updated from ReadyNASOS 6.2.5 (ReadyNASOS) to 6.5.1 (ReadyNASOS).
[2016/09/20 10:50:35] Updated from ReadyNASOS 6.5.1 (ReadyNASOS) to 6.5.2 (ReadyNASOS).
[2016/10/06 15:31:19] Updated from ReadyNASOS 6.5.2 (ReadyNASOS) to 6.6.0 (ReadyNASOS).
[2016/10/31 07:49:08] Updated from ReadyNASOS 6.6.0 (ReadyNASOS) to 6.6.0 (ReadyNASOS).And my older ReadyNAS has:
[2013/09/13 02:45:24] Factory default initiated due to new disks (no RAID, no partitions)!
[2013/09/13 02:45:29] Defaulting to X-RAID2 mode, RAID level 1
[2013/09/13 02:45:57] Factory default initiated on ReadyNASOS .
[2013/09/12 19:33:50] Updated from ReadyNASOS 6.0.0 to 6.1.2.
[2014/01/01 10:02:24] Updated from ReadyNASOS 6.1.2 to 6.1.5.
[2014/02/24 08:31:51] Updated from ReadyNASOS 6.1.5 to 6.1.6.
[2016/02/15 18:57:31] Updated from ReadyNASOS 6.1.6 () to 6.2.5 (ReadyNASOS).
[2016/02/15 19:08:41] Updated from ReadyNASOS 6.2.5 (ReadyNASOS) to 6.4.2 (ReadyNASOS).
[2016/10/07 14:08:07] Updated from ReadyNASOS 6.4.2 (ReadyNASOS) to 6.6.0 (ReadyNASOS).
[2016/11/03 08:20:34] Updated from ReadyNASOS 6.6.0 (ReadyNASOS) to 6.6.0 (ReadyNASOS).Let me know if you need anything else. I was told there may be something wrong with a config file but no one seems to want to offer any assistance on that. It would be nice if you would give me a specific issue it may have and a few troubleshooting steps.
