dimitrin
May 01, 2017Aspirant
Readynas Replicate
I have two devices, one at home and one at a remote location and the home NAS backups up to the remote NAS on a schedule. All works fine but I have a lot of history folders within each of the backup ...
jak0lantash
May 01, 2017Mentor
I'm assuming you're using ReadyNAS Replicate, is that correct?
Afaik, during next run of the job, if successful, it will rotate (and flush) the old occurrences. Can you manually start the job to trigger that? Or do you fear not having enough space for a new occurrence?
dimitrin
Hi jak0lantash
Thanks, yes I'm using readyreplicate, it's set for daily back up so will automatically run again tonight but I've still got a backlog of previous folders. Can I just delete these (or least early ones)?
