motts1983
Oct 19, 2015Aspirant
ReadyNAS Replicate
I am having issues backing up my NAS using ReadyNAS Replicate. I am using a ReadyNAS 2120 v6.4.0. When I turn the service on, my NAS gets unresponsive. I am unable to do any kinds of backups (usb ...
motts1983
Oct 21, 2015Aspirant
I am running the app SMB Plus. I did not have this issue when I was on 6.4.0. I am currently locked out of my dashboard and the only way to access it is to power cycle the device.
JennC
Oct 21, 2015NETGEAR Employee Retired
Hello motts1983,
Is it when you enable ReadyNAS Replicate or the ReadyCloud? If ReadyNAS Replicate, is the ReadyCloud enabled too?
After power cycling the NAS, does it revert the ReadyNAS Replicate and ReadyCloud to disabled?
When both are disabled, do you get any trouble using the NAS?
- motts1983Oct 21, 2015Aspirant
I started with Replicate, Cloud, and Remote enabled. I have turned off all but replicate and tried it then. My unit still locked up. Now I turned off Replicate and I am having issues even backing up to a desktop portable hard drive connected through the top usb port in the back.
