DonQ
Aug 14, 2016Aspirant
ReadyNAS RN 204 and UPS
Hi I have recently purchased a RN 204 and looking to ad a UPS. Quite frankly I find all the information rather confusing .... probably says more about me than the info! All I want is a UPS to protect ...
- Aug 15, 2016
I have two CyberPower units: CP1350AVRLCD and CP1500AVRLCD. Both work with ReadyNAS. I use the 1500 to protect the RN202 and a nearby PC (the Nas is set up to do a graceful shutdown, I never bothered to do that with the PC).
DonQ
Hi mdgm, thank you. Sorry for my ignorance, but if there is monitoring via a USB doesn't that require some software on the USB, and hence must be compatible? Regards Stephen
mdgm-ntgr
Aug 14, 2016NETGEAR Employee Retired
It does need to be compatible with NUT (Network UPS Tools) which we run on the NAS.
As for sharing the UPS over the network with a Windows PC whilst this article is written for an older product this works similarly: http://home.bott.ca/webserver/?p=466
- DonQAug 15, 2016Aspirant
Thank you for your resposne. I do not want to share the UPS with a PC, just want to keep it simple.
Your respose however highlights my issue that there is some confusion. The Netgear website (see my original post) makes it clear that," When any UPS battery is low or when a power failure occurs, the ReadyNAS automatically shuts down gracefully."
This suggests three things:
1. that a USB connection is not required.
2. that compatability with NUT is not and issue.
3. that the NAS is monitoring the power supply without a USB and hence can a drop in power, i.e. low power status.
(I am not usre of the iinplication of 'power failuire' becuase I would have assumed that in a power failure the NAS stops working and cannot gracefully shut down.
However if a USB connection is used then and only then does compatibility with NUT become any issue. However I am not sure what advantages using nUT bestows on the likes of me! Except that it enables email alerts,
There thus seems to be two options:
1. Use any UPS and not manage it via the NAS. This still gives you the graceful shut down.
2. Use a ReadyNAS NUT compatible UPS and manage it via the NAS.
The web page empasis any UPS by italising the any --- this is why I think there are the two options.
The UPS I am considering is a PowerShield Defender (an Australian product) ( http://powershield.com.au/powersheild_product/defender/ ) However based on your earlier post I am in the process of looking at the alternative if iI can source one locally.
Again thank you
Cheers
Stephen
- StephenBAug 15, 2016Guru - Experienced User
Let's stop over-thinking the datasheet, that is just a distraction.
If the UPS isn't being monitored by the NAS (either over USB or the network), then the ReadyNAS will not gracefully shut down when the UPS battery drains.
(1) The RN204 can monitor a UPS that supports NUT directly by connecting the UPS to an RN204 USB port. NUT is being used over USB in this case.
(2) It can also monitor a UPS installed on another ReadyNAS (or a PC that has NUT installed) - in which case you do need to make sure the switch or router is also protected.
(3) It can also monitor a network UPS via SNMP.
A lot of UPS support NUT, and it is not a feature that UPS folks charge extra for.
Have you purchased a UPS? If so, what model?
If not, are you looking for advice on what works? If you want advice it would be useful to know your location.
As mdgm says, a lot of folks here use APC, but you do need to avoid UPS that use serial cables instead of USB. Cyberpower also works, and is what I use with my ReadyNAS (including an RN202).
- DonQAug 15, 2016AspirantThank you for the clarification. No I haven't purchased the UPS and yes I am looking for advice thanks but I thik that I now have the info I need. I spoke to the tech at Powershield, he said that the unit had been tested on Synology but not Netgear so that options seems a bit of a risk. If any Cybepower or APC with USB works then I will source one of those. Regards Stephen
