DonQ
Aug 14, 2016Aspirant
ReadyNAS RN 204 and UPS
Hi I have recently purchased a RN 204 and looking to ad a UPS. Quite frankly I find all the information rather confusing .... probably says more about me than the info! All I want is a UPS to protect ...
- Aug 15, 2016
I have two CyberPower units: CP1350AVRLCD and CP1500AVRLCD. Both work with ReadyNAS. I use the 1500 to protect the RN202 and a nearby PC (the Nas is set up to do a graceful shutdown, I never bothered to do that with the PC).
DonQ
Aug 15, 2016Aspirant
Thank you for the clarification. No I haven't purchased the UPS and yes I am looking for advice thanks but I thik that I now have the info I need. I spoke to the tech at Powershield, he said that the unit had been tested on Synology but not Netgear so that options seems a bit of a risk. If any Cybepower or APC with USB works then I will source one of those. Regards Stephen
Aug 15, 2016Guru - Experienced User
- DonQAug 17, 2016Aspirant
Hi StephenB .... thanks for the advice, have purchased CyberPower 1200 for the NAS, modem amd phone .... all set up and works fine. The UPS is recognised by the NAS and so all set uo for a graceful shutdown whne the inevitable power failure occurs. Regards Stephen
