melbourne
Dec 13, 2015Aspirant
ReadyNAS RN104 locks up after upgrade to 6.4.1
Hi, My RN104 has been stable for 15 months, after I upgraded to 6.4.1 when doing backups it now randomly locks up (no web interface response, LCD on unit goes off, power button does not work) and...
mdgm-ntgr
Dec 13, 2015NETGEAR Employee Retired
Are you running the anti-virus service?
Which services/apps are you running?
Do you have an open support case?
Can you send in your logs (see the Sending Logs link in my sig)?
melbourne
no anti-virus service is running (no apps are running)
service running SMB / ReadyDLNA (rarely used)
no open support case (i tried to lodge one, but it said after 90days the community here was my only support available, perhaps i'm mistaken ?)
sure will send through logs
thanks for your prompt reply
- mdgm-ntgrDec 13, 2015NETGEAR Employee Retired
Thanks for the logs. However they are flooded with messages about the resync. If the problem happens again after rebooting the NAS please download the logs ASAP and send them through.
- melbourneDec 13, 2015Aspirant
OK the resync should be finished sometime around the 17th December 2015. I assume you mean if it locks up again to download the logs within a few minutes of it booting ?
Cheers
- mdgm-ntgrDec 14, 2015NETGEAR Employee Retired
Yes, that's what I meant. I should have been clearer in what I said.
If you download the logs soon after rebooting after a lockup hopefully messages about the resync won't have had time to flood the logs yet.
