Wizliz
Jun 29, 2016Tutor
ReadyNAS RN104 Management services offline (fw = 6.5.0)
Been running flawless since 2014. Suddenly RN104 was found in hung state! Current firmware installed = 6.5.0 AV disabled All 4 HDD Green OK Unit responding to ping <1ms 100% RAIDar Status ...
- Jul 14, 2016
System is now back up n running!
Problem was that ReadyNAS OS had run out of space due to syslog files. I got remote help from Netgear support to solve the issue. Normally theese logs are supposedly cleared/wiped when doing FW upgrade, but apparantly this was not the case.
I have also bought another RN104 which will be used as remote site backup.
All personal data was intact, so i dont have to sleep in the doghouse anymore. :)
Now i will replicate all data to the new unit.
Case closed
BrianL2
Jun 29, 2016NETGEAR Employee Retired
Hi Wizliz,
Welcome to the community!
Can you try if you can boot up your unit in 'Volume Read-only' mode? If yes, backup your data via SMB and extract the logs.
Kind regards,
BrianL
NETGEAR Community Team
Wizliz
Jun 29, 2016Tutor
Hi Brian
Thank you for reply
I´m in read only mode now, but same situation, unable to browse SMB and download of logfiles is not working in RAIDar. Please advise.
- Jun 10, 2022Retired_Member
