Wizliz
Jun 29, 2016Tutor
ReadyNAS RN104 Management services offline (fw = 6.5.0)
Been running flawless since 2014. Suddenly RN104 was found in hung state! Current firmware installed = 6.5.0 AV disabled All 4 HDD Green OK Unit responding to ping <1ms 100% RAIDar Status ...
- Jul 14, 2016
System is now back up n running!
Problem was that ReadyNAS OS had run out of space due to syslog files. I got remote help from Netgear support to solve the issue. Normally theese logs are supposedly cleared/wiped when doing FW upgrade, but apparantly this was not the case.
I have also bought another RN104 which will be used as remote site backup.
All personal data was intact, so i dont have to sleep in the doghouse anymore. :)
Now i will replicate all data to the new unit.
Case closed
Wizliz
Jun 30, 2016Tutor
Anyone else has a suggestion? I really need to get the system up'n running with data intact.
This Netgear NAS contains large amounts of precious family pictures and videos accumulated for many years, so loss of data is not an option.
To me this seems to be a Netgear OS bug introduced in the v6.5.0 fw hence a problen like this should be included and officially adressed for free by Netgear support.
AFAIK all HW is OK and no changes where made to the system after the recommended fw update was performed, i was not even at home when it stopped working a few days after the upgrade! :-(
Would it help if i transfer all four HDD to a similar RN104 or would the raid set be owerwritten/wiped?
- Jun 10, 2022Retired_Member
