Wizliz
Jun 29, 2016Tutor
ReadyNAS RN104 Management services offline (fw = 6.5.0)
Been running flawless since 2014. Suddenly RN104 was found in hung state! Current firmware installed = 6.5.0 AV disabled All 4 HDD Green OK Unit responding to ping <1ms 100% RAIDar Status ...
- Jul 14, 2016
System is now back up n running!
Problem was that ReadyNAS OS had run out of space due to syslog files. I got remote help from Netgear support to solve the issue. Normally theese logs are supposedly cleared/wiped when doing FW upgrade, but apparantly this was not the case.
I have also bought another RN104 which will be used as remote site backup.
All personal data was intact, so i dont have to sleep in the doghouse anymore. :)
Now i will replicate all data to the new unit.
Case closed
BrianL2
Jun 30, 2016NETGEAR Employee Retired
Hi Wizliz,
Sorry for the late response. Aside from getting help support and paying them, you can try and put your HDDs on a similar RN104 unit with the same firmware running. I suspect that there might be a problem with a drive or two on your system and more likely you will get the same behavior.
Kind regards,
BrianL
NETGEAR Community Team
Wizliz
Jul 01, 2016Tutor
Hi
I am now running disk diagnostic which will take several hours. I personally beleive all my drives are 100% working there are no errors on any of my drives. I have alerts notifications configured which previously have worked perfect when the occasional drive have failed and then been replaced.
So...
If i create the ReadyNAS OS 6: USB Recovery Tool, can/should i remove/pull out my 4 HDDs and try a FW upgrade (to 6.5.1) with no disks inserted? And if/when FW 6.5.1 upgrade is succesful then power down and reinsert my data disks in the same slot as before or will all RAID information with my data be wiped???
