Wizliz
Jun 29, 2016Tutor
ReadyNAS RN104 Management services offline (fw = 6.5.0)
Been running flawless since 2014. Suddenly RN104 was found in hung state! Current firmware installed = 6.5.0 AV disabled All 4 HDD Green OK Unit responding to ping <1ms 100% RAIDar Status ...
- Jul 14, 2016
System is now back up n running!
Problem was that ReadyNAS OS had run out of space due to syslog files. I got remote help from Netgear support to solve the issue. Normally theese logs are supposedly cleared/wiped when doing FW upgrade, but apparantly this was not the case.
I have also bought another RN104 which will be used as remote site backup.
All personal data was intact, so i dont have to sleep in the doghouse anymore. :)
Now i will replicate all data to the new unit.
Case closed
Jul 01, 2016Guru - Experienced User
Tech support mode is for remote netgear support. You need to communicate the debug code to Netgear as part of the support process.
Wizliz wrote:
Now i have restarted and then entered Tech Support Mode. Reported firmware is v6.5.1 with debug code: 60138 whatever that means?
Wizliz
Jul 14, 2016Tutor
Case closed
