Marcus-BIP
Mar 20, 2023Aspirant
Readynas RN214 crashing a few minutes after booting.
I have 2 RN214 units in my office. One works faultlessly and the other did but now crashes a short while after booting. Both are 214s running 6.10.8 firmware. Neither system is more than 65% full. ...
Mar 20, 2023Guru - Experienced User
I would try booting the NAS read-only next, and see if that is stable. Instructions are on pages 58-59 here:
Maybe also disable snapshots for all shares (if you haven't already).
Marcus-BIP
Mar 24, 2023Aspirant
Thanks StephenB .
I've booted the unit up in read only mode and it certainly stays alive longer, more than a few minutes, than in normal mode. So I'm assuming the problem is something is trying to write to the discs and causing the issue.
I gave the unit half an hour and then rebooted in normal mode. Same problem, as expected. However I tried to start disabling the snapshots but the unit crashed before any of the changes could be applied. Naturally I can't make changes in read-only mode so how would you suggest I proceed from here, please?
Cheers,
Marcus
- StephenBMar 24, 2023Guru - Experienced User
I suggest booting up again in read-only mode, and then making a full backup of the NAS. If you don't have the full log zip file, you could download it, and we can see if there are any more clues. But the logs usually don't get much when the system crashes.
After the data is safe, I'd try an OS reinstall. I'd judge the odds of success as low, but it is easy and safe to try.
The next step would be to test the disks. Normally there is a disk test on the volume settings wheel, but that might not be available in read-only mode. If that can't be run, you can test them in a Windows PC using vendor tools (Seagate's Seatools, or WD's Dashboard). Power down the NAS before removing disks for testing (and leave it powered down until the disks are reinserted). I label my disks by slot as I remove them, so I can return them to the same slot.
Another path (painful) is to just do a factory default, recreate the share and config, and restore the files from the backup. If it is a failing disk, the factory default will likely fail.
- Marcus-BIPMar 25, 2023Aspirant
The system logs are available. But, I'd assume, there is too much info to post here. Any thing/file specifically that would be helpful? Also I don't know if there is any personal information in there without going through them. If there isn't I can drop the zip file in.
However, backing up 14TB of NAS isn't always the easiest of propositions! But I might be able to work something out, but not having to backup, which really was the point of a NAS 🤣, would be handy.
Cheers,
Marcus
- StephenBMar 25, 2023Guru - Experienced User
Unfortunately, misguided. RAID isn't enough to keep data safe. ReadyNAS do need to be backed up.
My own primary ReadyNAS (30 TB volume) is backed up to other NAS. Though USB drives are another common approach. A 16 TB USB drive is about $250 USD at the moment.
There is some personal info in the logs, so best not to post them publicly. If you trust me to take a look, you can send me a private message (PM) using the envelope icon in the upper right of the forum page. You'd need to put the zip into cloud storage (dropbox, google drive, etc), and put a download link in the PM.
I'd be looking first for disk and filesystem errors, and also if there were any errors logged right before the system hung.
