Micmap
May 05, 2016Aspirant
Readynas RN314 during firmware update hangs during reboot process, what to do?
Hello, I hope somebody can help me with what to do. I wanted to update the readynas firmware (for readycloud->mynetgear account migration). It downloaded the firmware. But after I clicked reboot...
Micmap
May 06, 2016Aspirant
Indeed the firmware update was from 6.?.? to 6.4.2
I left the nas untouched overnight, and it looks like it now has rebooted without problems. I only did take a lot of time apparently.
But it's operating normal again, and the admin page shows 6.4.2. as the installed firmware.
(checking for updates indeed indicates that there are no newer versions available)
But problem solved, will remember that re-booting can/will take a lot of time.
mdgm-ntgr
May 06, 2016NETGEAR Employee Retired
When you first update to 6.4.x it can take a lot of time to calculate the quotas especially if you have a lot of snapshots. Now that you are running 6.4.x the update to 6.5.0 should be much quicker.
- MicmapJun 01, 2016Aspirant
Ok so this week I started migrating from readycloud to mynetgear account.
And the nas started updating the firmware to 6.5...
But now it's the same problem, the NAS hangs during reboot, it's already been 36 hours. No idea if it is ever going to come out of it. But I dont dare to touch anything because I'm, afraid of losing data or corrupting the firmware.
So again my question is, what to do? Wait this one out?
- MicmapJun 03, 2016Aspirant
NAS is still stuck and waiting to restart, please advice!
Can someone change this topic to unsolved? Or should I start a new thread?
I'm not touching the nas before I know what to do to resolve my problem.
I cannot reach the nas through the LAN interface, so I only have the buttons on the device to do something.
- StephenBJun 03, 2016Guru - Experienced User
I revoked the solution...
Try downloading RAIDar 6, and see what status it gives.
If you purchased your RN314 new, then you might be entitled to lifetime chat support. So you could also try support.netgear.com.
