akorinek
May 31, 2016Aspirant
Readynas RN314 iscsi errors
I created an iscsi share on my ReadyNAS RN 314. The NAS and the linux client are connected via dedicated Gigabit Ethernet. Under write load, there are i/o errors writing to the file system. The me...
mdgm-ntgr
May 31, 2016NETGEAR Employee Retired
Please send in your logs (see the Sending Logs link in my sig).
akorinek
Jun 01, 2016Aspirant
I've just sent the logs, thanks for looking into this.
- mdgm-ntgrJun 01, 2016NETGEAR Employee Retired
Your data volume is very full. You should try to keep it under 80% full.
Also RAID-0 is not recommended. It would be much better to use e.g. RAID-10.
- akorinekJun 02, 2016Aspirant
Hi,
I tried using raid5 now and a iscsi file with 75% of the total size of the raid, I still get the same error.I've sent a new log file.There are reports of similar problems with iscsi to be found on google, usually the suggested workaround is to change vm.zone_reclaim_mode to 1. However I cannot find that file in /proc on the NAS.See this link: https://access.redhat.com/solutions/90883Best regards,Andreas
