qdavis
Jan 05, 2017Aspirant
ReadyNas RN31400 stuck in boot at "Encryption Key 53%" followed by "Fail to startup"
I have a ReadyNas 314 running firmware 6.6.0. It's been running for about 3 years, with dual 2 TB hard drives, with encryption. The drives are about 70% full, and the performance started dropping. ...
PiersC
Mar 24, 2017Aspirant
How did you manage to get it to finish? mine is stuck on 48% and then i get __out_of_memory_354 errors
mdgm-ntgr
Mar 25, 2017NETGEAR Employee Retired
qdavis had a lot of snapshots on his system. He contacted support and the solution recommended involves reducing the number of snapshots and disabling quotas at the volume level (since 6.4.x quotas are disabled at the volume level regardless of whether you set a quota on the share). A GUI option to disable quotas has been added in 6.7.0. Before 6.7.0 if you disable quotas from the backend and then change a share setting quotas would be enabled again.
6.7.0 is currently in beta and should be ready for release soon.
