qdavis
Jan 05, 2017Aspirant
ReadyNas RN31400 stuck in boot at "Encryption Key 53%" followed by "Fail to startup"
I have a ReadyNas 314 running firmware 6.6.0. It's been running for about 3 years, with dual 2 TB hard drives, with encryption. The drives are about 70% full, and the performance started dropping. ...
Retired_Member
Apr 17, 2017i too am having issues with the encryption key boot up now. i went from a working frimware 6.2.4 to boot once 6.7.0 firmware. sometime during the night i got the "out of memory error" attempted to reboot, the nas started to boot, got to encryption key 99% and hung for over an hour, rebooted again, got to encryption key 53%, tried this several more times and the boot process hangs in the encryption key process between 43%-72% now. if i leave it in this state i can not get to the GUI, if i remove the encryption key, i get the nas to boot all the way, but i am not able to see the volume/shares (which make sence as they need the encryption key to unlock the volume. i also tried a new copy of the encryption key file to no avail.
any ideas i can try?
remove snapshots as indicated in an earlier post? what commands to do this?
try a downgrade back to 6.2.4?
thank you for any help you can provide.
