qdavis
Jan 05, 2017Aspirant
ReadyNas RN31400 stuck in boot at "Encryption Key 53%" followed by "Fail to startup"
I have a ReadyNas 314 running firmware 6.6.0. It's been running for about 3 years, with dual 2 TB hard drives, with encryption. The drives are about 70% full, and the performance started dropping. ...
jak0lantash
Apr 17, 2017Mentor
You can't downgrade. Your OOM issue is related to 6.7.0. Look at the release notes of 6.7.1 Beta 1.
- Retired_MemberApr 17, 2017
thank you, so is that saying that the OOM is what is stopping the encryption key enumeration process that is hanging the boot up? how can i check that this is the problem and not the quota/snapshot issue that i have read other are having?
thank you for your time and help.
- jak0lantashApr 17, 2017Mentor
That is saying that the NAS may run into OOM condition, encryption key or not. I just hit it with mine.
That's one obstacle. I'm not saying using 6.7.1 beta 1 is going to solve all your problems, but it's supposed to solve this one (OOM).
ok, guess i have two issues then, one being the OOM and the second is that the NAS will not boot with the encryption key in the usb port. if i remove the usb, the NAS will boot after its timeout of lookig for the usb encryption key, but the volume is not accessable to disable the quotas/snapshots, if that is what is causing the non-boot issue. so is there a set of SSH commands to see if the quota/snapshot issue is what is causing my problems?
