qdavis
Jan 05, 2017Aspirant
ReadyNas RN31400 stuck in boot at "Encryption Key 53%" followed by "Fail to startup"
I have a ReadyNas 314 running firmware 6.6.0. It's been running for about 3 years, with dual 2 TB hard drives, with encryption. The drives are about 70% full, and the performance started dropping. ...
Retired_Member
Apr 17, 2017thank you, so is that saying that the OOM is what is stopping the encryption key enumeration process that is hanging the boot up? how can i check that this is the problem and not the quota/snapshot issue that i have read other are having?
thank you for your time and help.
jak0lantash
Apr 17, 2017Mentor
That is saying that the NAS may run into OOM condition, encryption key or not. I just hit it with mine.
That's one obstacle. I'm not saying using 6.7.1 beta 1 is going to solve all your problems, but it's supposed to solve this one (OOM).
- Retired_MemberApr 17, 2017
ok, guess i have two issues then, one being the OOM and the second is that the NAS will not boot with the encryption key in the usb port. if i remove the usb, the NAS will boot after its timeout of lookig for the usb encryption key, but the volume is not accessable to disable the quotas/snapshots, if that is what is causing the non-boot issue. so is there a set of SSH commands to see if the quota/snapshot issue is what is causing my problems?
- jak0lantashApr 17, 2017Mentor
If you're ok with running a beta F/W, I think the easier way is to upgrade to 6.7.1 Beta 1, so you don't have to worry about the quotas for now. (6.7.1 Beta 1 is supposed to fix the OOM issue)
Then you can focus on the encryption key issue.
Alternatively, you may contact NETGEAR Support so they help you with addressing both issues at the same time.
im ok with trying the beta, i looked on the firmware page and also attempted to do a search for the 6.7.0 beta 1 firmware, did not find them, additionally the 6.7.0 page has been taken down. so do i need to contact someone to attempt the 6.7.0 beta 1 upgrade?
