Eredar
Nov 26, 2025Aspirant
ReadyNAS RN4220 wont boot up after shutdown from WebUI
Hello to anybody who can help, I got a ReadyNAS RN4220 out of eWaste from some company, and it worked perfectly! I have 100tb of NAS HDD storage in it and it has run fine for over a year now. ...
Eredar
Dec 04, 2025Aspirant
Thank you again for the help... here's the update.
New RAM did not fix the NAS, same issues as before. As its not even posting it is likely that its a parts issue with something more in depth, don't believe its both PSUs, maybe a blown capacitor on the board or something.
Probably just going to start looking into a replacement unit of an OS6 unit with 6-12 drives and try recover the data that way. Thank you all for the help in some debugging i think it was worth to try and recover the unit, but if it was that fragile to begin with it was a disaster waiting to happen at some point anyway.
If you have any reccos on a good one (pref rack mount) let me know, or anything i should look out for.
Thanks once again.
