jlficken
Aug 01, 2017Aspirant
ReadyNAS RN524X CPU temperature too high?
I have a RN516 at home and we just got a RN524X at work. My RN516 CPU temp runs 35C at idle while the RN524X is running 55C+ (I have seen 63C a few times). Is this normal? I know that the max i...
Aug 01, 2017Guru - Experienced User
My RN524X is normally powered down during the day, but I just booted it - it came up with showing disk temp of 29C and the CPU temp of 55. FWIW The fan is set to balanced.
- jlfickenAug 01, 2017Aspirant
Ok. Right now it is 47C so it just must hotter than my RN516.
- Marty_MAug 02, 2017NETGEAR Employee Retired
Hello jlficken,
The temperature of the NAS will also affected by the environment where the NAS is located and also the processes that is running on the NAS.
Marty_M
NETGEAR Community Team- StephenBAug 02, 2017Guru - Experienced User
Marty_M wrote:
The temperature of the NAS will also affected by the environment where the NAS is located and also the processes that is running on the NAS.That is of course true. Though the RN524x CPU does seem to run hot - it is quite a bit hotter than my RN526x CPU temp, and they are co-located.
