ronaldvr2132
Apr 25, 2019Apprentice
ReadyNAS RN628X stuck booting after confirming reboot to install firmware 6.10.0
I have seen several people having the same issue and reading about a USB recovery option or something. My RN628X won't boot nor does the boot menu can be opened with the option to press the reset but...
JohnCM_S
May 07, 2019NETGEAR Employee Retired
Hi zeke561,
Can you also connect a PC to the NAS console port? Check the console output while the NAS is booting and also while you are doing a USB boot recovery. We need some information on console so we can check what is happening during the booting process and also during the USB boot recovery.
zeke561
May 07, 2019Guide
Yes I will try that.
- zeke561May 07, 2019Guide
This is what I get when the system tries to boot. This is actually after the fact, because the putty session crashes when I power the device off because it can't read from the serial device. :
SYSLINUX 4.06 EDD Load error - Boot error
Reboot and Select proper Boot device
or Insert Boot Media in selected Boot device and press a keyI can't really try to see what's going on while I try a USB recovery, because of what I noted above. But after the fact I get the same error as above.
- ronaldvr2132Jun 12, 2019Apprentice
I received my replacement NAS today and before I am going to put my old disks in (in the same sequence) I want to understand a bit how configs and OS is stored on the ReadyNAS devices. I came across a thread linked to this threat where the following steps were advised:
1. Start by doing a clean install in the replacement NAS using a scratch disk (not in the array, as it will be reformatted). Then install 6.10.0 on the NAS.
2. After that, power down and insert your original disks.
3. Power up, the system should either
a. immediately come up or
b. install 6.10.0 on the disks, and then come up.This seems as a good start which I for sure will try. Before I take an action I later regret I want to make sure that the above is not influenced by:
1. The OS on the hard disks of my old NAS is probably 6.10.0 and the latest version now is 6.10.1. So if I do step one now firmware 6.10.1 will be on the NAS;
2. I have encrypted my hard disks and use an USB stick from which the key is loaded when I start-up the NAS. Could this influence the above steps.
Thinking about the steps are my assumptions correct that:
1. The configuration is only stored on the hard disks (as a clean install with a new hard disk and then replace the hard disk with the old ones should restore my old data and functionality and that makes me think that the confguration is on the harddisks and not on the read only memory of the NAS itself. Is this assumption correct?;
2. The OS itself is installed on both the read only memory and the hard disks and in normal situations when the OS is corrupted on the NAS it will be loaded from the hard disks again.Again is this assumption correct?
Again I want to understand what is stored where (on the read only memory of the NAS itself or the harddisks or on both) to have a bit of extra comfort level that after updating the firmware on the replacement NAS (from the supplied 6.6 to 6.10.1) and then powering it down, putting my old hard disks in and restarting it will result in my old functionlity and data restored. I don't have any apps installed and only use of what is native included in the OS of the RN628X.
- StephenBJun 12, 2019Guru - Experienced User
Yes
As far as it goes yes. Another aspect is what happens if the version of the OS on the disks differs from what it is in the flash memory.
If that is the case, then in an OS-6 NAS the newest version wins. That is, if the flash memory holds 6.10.1 and the disks hold 6.10.0, then the disks will be updated to 6.10.1. If the flash memory holds 6.10.0 and the disks hold 6.10.1 then the flash is updated.
The idea of updating the flash with the scratch disk first is to minimize the mismatch - preferrably not updating either the the disks or the flash memory until you are ready/willing to do that.
I'm not sure how you are reaching that conclusion. You can install 6.10.0 manually on the scratch disk - either upgrading (or downgrading) the flash memory. Either way, you can ensure that 6.10.0 is in the flash before you migrate the disks.
- ronaldvr2132Jun 13, 2019Apprentice
Hi StephenB thank you very much for the clarrification. I will manually update the new NAS to 6.10.0 and then migrate the harddisks over. Fingers crossed all data and configs is still there. Thanks again.
- ronaldvr2132Jun 15, 2019Apprentice
After receiving my replacement RN628X I updated the firmware to V6.10.0 with a new initial install using a new hard disk. After this firmware update I have shut down the NAS and replaced the new hard disks by my old hard disks and started the NAS up again and now it is up and running again. Although I hope Netgear can find a solution that prevents that a ReadyNAS get's bricked with a firmware update, I am happy with the provided solution and support!
