ronaldvr2132
Apr 25, 2019Apprentice
ReadyNAS RN628X stuck booting after confirming reboot to install firmware 6.10.0
I have seen several people having the same issue and reading about a USB recovery option or something. My RN628X won't boot nor does the boot menu can be opened with the option to press the reset but...
ronaldvr2132
Jun 12, 2019Apprentice
Hi StephenB thank you very much for the clarrification. I will manually update the new NAS to 6.10.0 and then migrate the harddisks over. Fingers crossed all data and configs is still there. Thanks again.
ronaldvr2132
Jun 15, 2019Apprentice
After receiving my replacement RN628X I updated the firmware to V6.10.0 with a new initial install using a new hard disk. After this firmware update I have shut down the NAS and replaced the new hard disks by my old hard disks and started the NAS up again and now it is up and running again. Although I hope Netgear can find a solution that prevents that a ReadyNAS get's bricked with a firmware update, I am happy with the provided solution and support!
