byroman777
Nov 14, 2018Aspirant
readynas RND2000 duo V2
He started to hang after the end of the guarantee, more often when downloading torrents, although I did not usually download more than two at the same time. I did OS REINSTALL after reinstalling the ...
Nov 14, 2018Guru - Experienced User
What firmware are you running?
Do you have ssh enabled?
- byroman777Nov 15, 2018Aspirant
- RAIDiator-arm Version 5.3.13 (for ReadyNAS Duo v2/NV+ v2)
- no
- StephenBNov 15, 2018Guru - Experienced User
Since the hangs continued after a factory default, it seems to me that this is more likely to be a hardware issue than a software one.
I'd start by testing the disks in a Windows PC (connecting with either SATA or a USB adapter/dock). WDC's lifeguard software is the best way to test the WD disk. I think you can also run the generic long test on the Toshiba using lifeguard. If you don't know the SMART stats on the drives, you should also look at those.
Another thing you could try is exercising the Duo w/o the torrent app installed. You could use NAS tester for this (setting a high number of loops). http://www.808.dk/?code-csharp-nas-performance
- byroman777Dec 10, 2018Aspirant
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 800MB file write on \\192.168.1.56\media\Videos 4 times...
Iteration 1: 27,60 MB/sec
Iteration 2: 23,34 MB/sec
Iteration 3: 29,97 MB/sec
Iteration 4: 31,60 MB/sec
Average (W): 28,13 MB/sec
Running a 800MB file read on \\192.168.1.56\media\Videos 4 times...
Iteration 1: 19,47 MB/sec
Iteration 2: 18,82 MB/sec
Iteration 3: 18,88 MB/sec
Iteration 4: 24,77 MB/sec
Average (R): 20,48 MB/sec
-----------------------------After the NAS reboot, the result is:
Running warmup...
Iteration 1: 40,47 MB/sec
Iteration 2: 41,48 MB/sec
Iteration 3: 39,42 MB/sec
Iteration 4: 40,49 MB/sec
Average (W): 40,47 MB/sec
Iteration 1: 77,45 MB/sec
Iteration 2: 74,94 MB/sec
Iteration 3: 78,35 MB/sec
Iteration 4: 76,27 MB/sec
Average (R): 76,75 MB/sec-----------------------------
The day after the reboot, the speed drops. And so always. What could be the problem?
