Chiragtailor
Jan 03, 2022Aspirant
ReadyNas RND4000 v3 not powering on after power cut
Hi there I have a RND4000 v3 (couldn't find this listed in model numbers but the device has number RND4250V3 and RND4450V3 listed too) and after a power cut the device is no longer powering on. I've ...
- Jan 03, 2022
Chiragtailor wrote:
I have a RND4000 v3 (couldn't find this listed in model numbers but the device has number RND4250V3 and RND4450V3 listed too)The part numbering system can be confusing.
You have hardware revision 3 of the original NV+. We call all of the original (sparc-based) platforms "NV+ v1" here.
Chiragtailor wrote:
Can anyone help direct me to a site or seller in the UK that can supply the part and guidance on how to replace it, far too technical for me.Here is one supplier: https://www.ebay.co.uk/itm/323971676540 Note it is possible to get "stock" supplies, perhaps for a bit less. But you'd need to make a change to the wiring in order to use them.
Netgear's instructions on replacement are here: https://www.downloads.netgear.com/files/GDC/READYNAS-COMMON/Replacing%20the%20PSU.pdf
Chiragtailor wrote:
I hear a clicking noise when I plug the kettle lead inTry removing all the disks (powered down) - labeling them by slot number as you remove them. Then power up the NAS, and see if you still hear the clicking sound. Also, check if the LCD displays "no disks" or not.
If you see "no disks", then it is possible that you have a failed disk, and not a bad PSU. In this situation, try
- installing disks 2, 3, 4 in their original slots (leaving bay 1 empty).
- Power up, and see if the system boots.
If this fails, try again with disks 1, 3, 4 (again, in their original slots), followed by 1, 2, 4 and 1, 2, 3.
If you find a combination that boots, offload your data immediately.
Jan 03, 2022Guru - Experienced User
- ChiragtailorJan 03, 2022AspirantHi Stephen
I appreciate the really speedy response and thanks for clarifying the point about the model numbers.
I am not getting any response when pressing the power button, the clicking I referred to was as the kettle lead goes into the socket.
I hope you don't mind but I've included some pictures of the device and want to just double confirm that it is the right part you provided?
Do you mind if I send- ChiragtailorJan 03, 2022AspirantAnother image
- StephenBJan 03, 2022Guru - Experienced User
Chiragtailor wrote:
I hope you don't mind but I've included some pictures of the device and want to just double confirm that it is the right part you provided?Definitely the original NV+. FWIW, I have one with the same v3 label as well. I don't use it for primary storage anymore, but I do use it to back up some files on my primary NAS.
4.1.7 was released in Nov 2010, so the NAS would have been manufactured in late 2010 or 2011.
- ChiragtailorJan 03, 2022AspirantGreat thank you.
Will this one be suitable?
https://www.ebay.co.uk/itm/Readynas-NV-NV-NVX-1100-1500-2100-PSU-Replacement-for-ReadyNAS-ST-220FUB-/153194477973?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
Just conscious that the one you sent it coming from Texas and will take weeks without a return policy, whereas this is UK and accepts returns? Thanks
