MikeH1
Mar 10, 2018Tutor
ReadyNAS NV+ RND4000 Power Supply Replacement
It looks like the power supply on my NV+ RND4000 has died (this is actually the 2nd one that's died, so I've already performed the replacement once, a number of years ago). I've ordered a replacement, and am trying to remove the current PS, so the NAS is ready for installation as soon as the replacement PS arrives (need to start working on taxes, and guess where our recent tax info is?). Anyway.....
I'm following the PSU replacement procedure from this site, but I am stuck (rather, the bottom panel is stuck). The bottom panel with the rubber feet won't detach. There are no instructions specific to removal of this panel. I've tried "forcing" it as much as I dare.
Can anyone offer advice on what the "trick" might be to removing this panel?
Thanks,
Mike
Nevermind, found the problem. I missed a screw. It was hiding under the "warranty void" sticker.
Oddly enough, the instructions say to disregard the sticker, which I clearly did. :smileywink:
1 Reply
- MikeH1Tutor
