colmosiris
Aug 03, 2015Aspirant
ReadyNAS model RND4000-100EUS - replacement power supply
Hi there! I have a ReadyNAS box that needs a new power supply. The box and cable that connects the NAS to the wall socket that is, not the internal power unit.
I've found some on ebay, but they mention ReadyNAS Duo, and mine isn't one, I don't think. Also, there are 1TB and 2TB versions, and again, I don't know what I need!
Tried Netgear, without success (can't get through), so am hoping some kind person on here can help me. Many thanks.
All you need is the correct cable, there is no transformer. The input voltage to the supply can be 100-240.
For instance this: http://www.amazon.co.uk/Mains-Cable-Power-Monitor-Kettle/dp/B003P49P1I
- colmosirisAspirant
Sorry, should have made it clear - I'm after the specs for the power supply I need! :)
- Davexyz2Aspiranttry a search on amazon using synology power supply yes not what you really expect. They the replacement supply works on readynas with a 4 pin plug. It will have the specs as well
"try a search on amazon using synology power supply yes not what you really expect. They the replacement supply works on readynas with a 4 pin plug. It will have the specs as well"
thanks, but i'm not really sure what you mean, i'm afraid. i did that search, and just found a load of nas boxces. Anyway, my NAS box doesn't have a 4-pin plug, it's a 3-pin kettle lead.
I also have a model RND4000-200EUS ReadyNAS box. That does have a 4-pin plug, like a little DIN plug.
