Genaudio
Jan 25, 2016Aspirant
ReadyNAS RNDP6000-200EUS - "Could Not Mount Root Raid d" #26374477
Hi All
My current ReadyNas RNDP6000-200EUS was only replaced under warranty back in July 2015, previously having a Pro Business Edition RNDP6350 with a failed power supply. Apparently my hardwa...
- Feb 01, 2016
No problem :)
kohdee
Feb 01, 2016Administrator
Looks like from your case you had a bad disk in the chassis.
Genaudio
Feb 01, 2016Aspirant
Actually it was a bad disk. The only problem is that I am not receiving any email notifications as no matter how I set my gmail and local account I get an SMTP error message. I have also enabled POP access on the gmail settings but still no luck. Any help?
- kohdeeFeb 01, 2016Administrator
There's a log called msmtp.log that'll explain why your e-mails are failing.
- GenaudioFeb 01, 2016Aspirant
kohdee thanks for your quick reply. Actually I have located this log file but honestly I have no idea what to do next ....... As you can see I have been trying for quite some time. Trying to upload the file.
You can perhaps copy the last 2 or 3 lines from the bottom of the log into this thread so I can review what it mentions.
Sometimes if you're using GMAIL, you have to enable some kind of advanced setting to authorize those connections. I'll see if I can locate the setting.
