TheBalconyMan
Mar 12, 2013Aspirant
ReadyNAS RNDU6000 & Total Anxiety!
Hello NetGear people. I recently bought a RNDU6000 system and since i am already the owner of a ReadyNAS Duo it was an awesome upgrade, but stuff went wrong and this is what happened: 01. The R...
TheBalconyMan
StephenB wrote: It shouldn't let you exceed them.
It is concerning that he only sees empty folders.
Yes, where could the data be?
I do see alot of "linuxlibraries" but i can't find my libraries, perhaps they are hidden somewhere among all those libraries?
Perhaps it's not possible to view one harddrive at a time? Maybe the data is spread out all over the 6 harddrives.
Man, i thought i was kick ass with this setup guess i was a little too eager to set things up :oops: .
I really hope there is a way to save it, the old 2TB harddrives that contained the origial data could maybe be a good choice to check
if one would give data recovery a try but what program is the best? And easiest?
Where on the 6TB harddrives should the data be? I mean among all those linux libraries?
