mattk91
Apr 05, 2021Aspirant
ReadyNas RnR-4B reset permissions
Good Morning, Our ReadyNas device reset all the permissions and we are unsure how. We also tried setting back to default but was unable to.
Apr 05, 2021Guru - Experienced User
Does this service action apply to your unit? https://kb.netgear.com/000037344/Service-Note-for-RN3130-RN3138-WC7500-and-WC7600v2
mattk91
No, the model we have is RNR-4B.
- StephenBApr 05, 2021Guru - Experienced User
I don't own a rack-mount but my understanding is that the RNR-4B is also known as the RN3138. So you might want to check the serial number.
Did you download the log zip file? That might give you a clue as to what happened.
Not sure what permissions are you talking about (network or file). If you mean file permissions - Did you use the reset control on fhe file access page after you set the permissions for the root folder of the share?
- mattk91Apr 05, 2021Aspirant
Thanks. I am going to check the logs but I am having trouble locating the IP address of the device. Would you happen to know where I can get this?
Update. I viewed the logs and don't really see anything out of the oridnary. Is there a specific event I should look for. Also, the permissions are file permissions. They are set through windows explorer normally.
