Grunbay111
Jul 27, 2015Aspirant
ReadyNAS Rsync to FreeNAS
I have a ReadyNAS running RAIDiator 4.2.27 (the latest version) that is attached to my home network. I have installed the latest firmware updates to the NAS. My home network has no directory service ...
BrianL2
Jul 27, 2015NETGEAR Employee Retired
Hi Grunbay111,
Not sure if you have check this article already. If the RSYNC backup still won't work, I suggest you to open a ticket with NETGEAR support.
Kind regards,
BrianL
NETGEAR Community
- Grunbay111Jul 27, 2015Aspirant
Thanks BrianL. I had not seen that article, but had read a very similar article in netgear support. Unfortunately, both articles discus using rsync between two ReadyNAS boxes, not ReadyNAS and FreeNAS. I have followed all of the relevant suggestions on my ReadyNAS.
- BrianL2Jul 27, 2015NETGEAR Employee Retired
Hi Grunbay111,
If that is the case, have a quick check with our support team and see if what other things they can suggest.
Kind regards,
BrianL
NETGEAR Community - mdgm-ntgrJul 27, 2015NETGEAR Employee Retired
Hi Grunbay111 on which NAS will you be running the backup job?
The Rsync service/module would need to be configured on the other NAS.
So setting up read-only Rsync access to the share on the ReadyNAS would be so that you could run a backup job on the FreeNAS device using the ReadyNAS as the Source and a share on the FreeNAS device as the destination.
Enabling the Rsync module for the share on the FreeNAS device would be so that you could run a backup job on the ReadyNAS to backup the data to the FreeNAS device.
So you could try creating a backup job on the ReadyNAS with the source share as the source and the destination as a Remote Rsync Server with the host as 192.168.1.145 and the path "ReadyNASBackup" (no quotes). You can enter the Rsync credentials if needed.
