Scampicfx
Nov 02, 2017Aspirant
XS716T with LACP and FreeNAS
Dear community,
I'm just about to setup LACP in my network in order to provide link redundancy when accessing our FreeNAS server. I updated firmware of XS716T to newest version 6.6.3.3. When creating the link aggregation, however, I'm not sure what to select at "Hash mode".
There are 6 different options:
- 1 Src MAC, VLAN, EType, incoming port
- 2 Dest Mac, VLAN, EType, incoming port
- 3 Src/Dest MAC, VLAN, EType, incoming port
- 4 Src IP and Src TCP/UDP Port fields
- 5 Dest IP and Dest TCP/UDP Port fields
- 6 Src/Dest IP and TCP/UDP Port fields
As far as I remember, mode 3 is the most compatible mode. However, I have read that selecting mode 6 will give maximum performance and reliability? What mode should be selected when link redundancy is the number one priority?
Is it correct to set STP mode and Link Trap on "enabled"?
Thanks so much for your help!
Kind Regards,
Scampicfx
Hi Scampicfx,
Welcome to the community! :)
As far as I have researched online, Hash Mode 3 (Src/Dest MAC, VLAN, EType, incoming port) is compatible for most scenarios while Hash Mode 6 (Src/Dest IP and TCP/UDP Port fields) is used when dealing with virtual machines such as Hyper V. As reference, kindly access and read the forum links below:
https://community.spiceworks.com/topic/302625-hash-mode-and-lag-between-switches
https://www.reddit.com/r/sysadmin/comments/i8mbo/lag_hash_mode_settings/
About your concern on which Hash Mode to select for redundancy for the FreeNAS, though I am not familiar with FreeNAS, however, I suggest you to use Hash Mode 3 (Src/Dest MAC, VLAN, EType, incoming port) if ever the FreeNAS supports a Hash Type of Layer 2+3.
You may leave the STP mode and Link Trap enabled as these are needed to prevent loops.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi Scampicfx,
DaneA
NETGEAR Community Team- ScampicfxAspirant
Dear DaneA,
thanks so much! I did so and it's running fine :)
