Grunbay111
Jul 27, 2015Aspirant
ReadyNAS Rsync to FreeNAS
I have a ReadyNAS running RAIDiator 4.2.27 (the latest version) that is attached to my home network. I have installed the latest firmware updates to the NAS. My home network has no directory service ...
Grunbay111
Very helpful post, I was able to get the job to run, but it fails. I will play with it a bit and get back to you.
Thanks a million!
mdgm-ntgr
Jul 27, 2015NETGEAR Employee Retired
Which version of Rsync is running on FreeNAS?
When the job fails do you get an error message or a log explaining why?
- Grunbay111Jul 28, 2015Aspirant
I am running the Rsync version that came with my Stable FreeNAS download. I don't know what version that is. How do I confirm?
A log report from the faied backup is shown below:
NCREMENTAL Backup started. Tue Jul 28 00:18:16 EDT 2015
Job: 001
Protocol: rsync
Source: [Backup2]/
Destination: 192.168.1.145::Backup2TestModule
sending incremental file list
rsync: chgrp "/.AppleDB" (in Backup2TestModule) failed: Operation not permitted (1)
.AppleDB/
.AppleDB/__db.001
.AppleDB/__db.002
.AppleDB/__db.003
.AppleDB/__db.004
.AppleDB/__db.005
.AppleDB/__db.006
.AppleDB/cnid2.db
.AppleDB/db_errlog
.AppleDB/lock
.AppleDB/log.0000000001
.AppleDesktop/.volinfo
KTM/
KTM/.AppleDouble/
Network Trash Folder/.AppleDouble/.Parent
Temporary Items/.AppleDouble/.Parent
rsync: chgrp "/.AppleDB/.__db.001.vSua0b" (in Backup2TestModule) failed: Operation not permitted (1)
rsync: chgrp "/.AppleDB/.__db.002.mrDw5b" (in Backup2TestModule) failed: Operation not permitted (1)
rsync: chgrp "/.AppleDB/.__db.003.HfLASF" (in Backup2TestModule) failed: Operation not permitted (1)
rsync: chgrp "/.AppleDB/.__db.004.vTYkIy" (in Backup2TestModule) failed: Operation not permitted (1)
rsync: chgrp "/.AppleDB/.__db.005.DHKgzU" (in Backup2TestModule) failed: Operation not permitted (1)
rsync: chgrp "/.AppleDB/.__db.006.8BTsQ7" (in Backup2TestModule) failed: Operation not permitted (1)
rsync: chgrp "/.AppleDB/.cnid2.db.9ST8HZ" (in Backup2TestModule) failed: Operation not permitted (1)
rsync: chgrp "/.AppleDB/.db_errlog.26Raex" (in Backup2TestModule) failed: Operation not permitted (1)
rsync: chgrp "/.AppleDB/.lock.FhxfMG" (in Backup2TestModule) failed: Operation not permitted (1)
rsync: chgrp "/.AppleDB/.log.0000000001.en7Qn4" (in Backup2TestModule) failed: Operation not permitted (1)sent 184475 bytes received 70299 bytes 169849.33 bytes/sec
total size is 37721190 speedup is 148.06
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1070) [sender=3.0.9]- siignaJul 28, 2015NETGEAR Employee Retired
ReadyNAS is trying to preserve permissions on files when transferring them over to FreeNAS, but is having a problem changing group ownership for some files (mostly OS X resource forks it looks like). Besides that looks like the files transferred over OK! You can ignore these errors, but annoyingly they'll still cause a backup job to show a "failed" status.
What do the permissions on the destination FreeNAS folder look like? You can open a shell in the FreeNAS UI and do an "ls -al /mnt/MirrorPool/ReadyNASBackup". You're still using Grunbay/Grunbay for User/Group in the rsync module settings?
