PerthPhil
May 16, 2017Tutor
ReadyNAS Shares not showing 'Available' and 'Consumed' space after rebuild
Last week I rebuilt an RN716x and 2x RN51600 Netgear ReadyNAS devices so I could encrypt all volumes. I did this progressively (moving data off one, performing a factory reset, manually creating enc...
- May 19, 2017
go shares and select settings then enable quota
JennC
May 19, 2017NETGEAR Employee Retired
Hello PerthPhil,
It does appear it is best to check this with the support team.
I checked your profile and found that you have registered all your ReadyNAS devices and one of them is entitled to a lifetime CHAT support.
I suggest contacting support team for this problem you raised.
Welcome to the community!
cpu8088
May 19, 2017Virtuoso
- PerthPhilMay 19, 2017Tutor
CPU8088 - you are a complete legend. In my case it was Volume | Settings | Enable Quota (I had switched it off without realising it was necessary for size calcs when encrypting drives) but the result was the same. Appreciate the heads up.
You saved me a lengthy tech support call and a huge amount of worry. Thanks immensely with much gratitude :)
