steveoelliott
Feb 23, 2009Luminary
Readynas Stuck in Booting...
Hi,
As requested started a new thread...
My box is stuck in the booting state and always takes at least 4-5 hours to boot. I've tried all the options. USB and TFTP updates etc and I've now got a case with the 3rd level engineers. I can arrange remote access right away.
Thanks...
Thanks...
- Dooku1AspirantSystem should be rebooting right now might take a while to boot up. please check if the system boots up properly.
- steveoelliottLuminaryHi,
The system hasn't come up as yet, I'm trying to access remotely. Although as you said it may take a little while.
Thanks... - steveoelliottLuminaryThe box didn't boot up overnight. When I came to it, it was still stuck in booting. I've power cycled it and again it is stuck in booting.
I can arrange remote access again if necessary.
Thanks... - steveoelliottLuminaryMy box has just came up after 5 hours. I've got the logs and will be sending them to you.
Cheers... - steveoelliottLuminaryJust too add some additional info. I had problems with backups prior to this issue.
- steveoelliottLuminaryI can give you remote access today. I've sent you a private message to arrange a time with you>
Cheers... - steveoelliottLuminaryAs requested, box is in telnet mode.
- steveoelliottLuminaryThanks for all your help on this Dooku.
For the benefit of others, this issue turned out to be some kind of defect relating to the USB setup. Apparently this will be fixed in the next firmware. - djmattybAspirantI am having the exact same problem. Stuck on "Booting..." How do I get my ReadyNas to boot?
- Jacob1AspirantSame here. I have ReadyNAS NV+ running the latest firmware. Today I had to shutdown the box to connect a new computer. During the reboot, the device gets to this point (shown below) and sits there forever:
Booting...
C: 0.3/1.3T free
Any advice would be greatly appreciated.
