Keligh
Mar 12, 2017Tutor
ReadyNAS stuck on 'Booting 0%'
Hi, My ReadyNas Ultra6 is stuck at 0% ben it boots. I have to do an OS Reinstall to be able to boot it. It works everytime but I know it's not meant to be done at each boot ... I've seen ano...
- Mar 13, 2017
mdgm wrote:The root volume should be well under half full normally. You should look into why the root volume usage is so high.
Ok, silly question but would you know lead lead as how i could investigate this ?Il already check var/logs but it didn't contain much. I don't really know where else to check.
SandsharkI've checked a couple of time and it doesn't seem to move.
But something must happen because now it's not random anymore: it stays up 2 days at most before freezing and needing a reboot :(
What really bugs me is that an OS Reinstall allows it to boot ... but then next boot it doesn't work again. what could change so quickly that prevent the NAS from booting properly after an OS Reinstall ?
Retired_Member
Mar 12, 2017As the antivirus service is no longer an app and being integrated into the os I wonder, whether you have that service currently enabled. If yes, please disable and see, whether it goes back to normal.
