ozlard
Aug 28, 2015Aspirant
Readynas Ultra 2 stuck on booting
Hello, Since a couple of days, my Ultra 2 Nas show me an corrupt root error. I tried several times to factory reset and os reinstall but it didn't worked : after reboot i always got an corrup...
- Aug 29, 2015
Hello JennC,
My problem has been remotely solved by 'mdgm' and to conclude : There was a corrupted file on the internal flash.
Thank you to all NETGEAR community team for your support !
JennC
Aug 29, 2015NETGEAR Employee Retired
Hello ozlard,
Here are steps we often do with cases like this.
- Factory reset with both disks inserted then try install again.
- Remove one of disks leaving one disk inserted, factory reset. If same problem remove the 1st disk you left inserted and insert the one you removed then try again
- Use diagnostic tools to check the disks diagnostic tools.
- If you have a spare disk, test it with the NAS too.
- USB boot recovery
If same results after all these, contact support center
- ozlardAug 29, 2015Aspirant
Hello JennC,
