Hanilc
Jan 16, 2021Aspirant
ReadyNAS Ultra 2 Volume C offline, 100 % used
Hi there, My NAS is no longer reachable. When I use RAIDar it says Volume C is offline and 100% used which is not correct. The IP address has been changed to 192.168.168.168 and doesn't listen to th...
Jan 17, 2021Guru - Experienced User
Hanilc wrote:
When I use RAIDar it says Volume C is offline and 100% used which is not correct. . What can I do solve the problem?
Start by downloading the log zip file from the admin web ui, and look for errors in there.
You can ask the mods to analyze the log zip for you by
- uploading the full log zip to cloud storage (google drive, dropbox, etc)
- send a private message (PM) to one of the mods ( JohnCM_S , Marc_V ) using the envelope icon in the upper right of the forum page.
- include a download link to the log zip in your PM, along with a link to this forum thread.
Don't post the log zip publicly.
Hanilc
Jan 17, 2021Aspirant
Logfile attached.
From the januari 3rd something has been wrong with the NAS.
Some translations of the log file:
Jan 3 2021 - Det gick inte att köra volymsökningen ordentligt - The volume search could not be run properly.
Sökvägarna till utdelningarna nedan hittades inte. - The paths to the shares below were not found.
Det beror vanligen på att Readynas inte har åtkomst till datavolymen. - This is usually because Readynas does not have access to the data volume.
BR Hanilc
