Hanilc
Jan 16, 2021Aspirant
ReadyNAS Ultra 2 Volume C offline, 100 % used
Hi there, My NAS is no longer reachable. When I use RAIDar it says Volume C is offline and 100% used which is not correct. The IP address has been changed to 192.168.168.168 and doesn't listen to th...
Hanilc
Jan 17, 2021Aspirant
Logfile attached.
From the januari 3rd something has been wrong with the NAS.
Some translations of the log file:
Jan 3 2021 - Det gick inte att köra volymsökningen ordentligt - The volume search could not be run properly.
Sökvägarna till utdelningarna nedan hittades inte. - The paths to the shares below were not found.
Det beror vanligen på att Readynas inte har åtkomst till datavolymen. - This is usually because Readynas does not have access to the data volume.
BR Hanilc
