Hanskemp
Aug 02, 2016Aspirant
ReadyNAS Ultra 4 default password fails after OS reinstall
After failing to logon to my ReadyNAS Ultra 4 as 'admin' using my regular password, I did a password recovery by entering my email address and answering the recovery question. It came back saying it ...
Aug 02, 2016Guru - Experienced User
Can you still access the data?
What firmware are you running?
Hanskemp
Yes, the data is still accessible.
The firmware I'm running is version 4.2.28
- JennCAug 02, 2016NETGEAR Employee Retired
Hello Hanskemp,
Can you try clearing cache? If same problem, maybe try another OS reinstall. Admin and netgear1 should be in lower cases, just in case.
- StephenBAug 02, 2016Guru - Experienced User
Hopefully Jenn's suggestion on the cache will work. If it doesn't, you could try per-incident paid support.
Either way I recommend making a backup. RAID isn't enough to keep your data safe.
- HanskempAug 03, 2016Aspirant
Thank you all for your suggestions so far.
I did clear the browser's cache, tried three different computers (OSX, Win10), using different browsers (Safari, Chrome, Edge, Firefox)... nothing. Same behavior everywhere: after entering default login data, a couple of seconds later a dialog pops up saying 'Verification required'.
I'm pretty damn sure I entered the login data correctly, at least on some occasions, I tried all available methods and various passwords... I know 'netgear1' (no quotes) is the right default password for my firmware version. =/
Will try another OS reinstall later today.
In the mean time... how do I apply for per-incident paid support?
- StephenBAug 03, 2016Guru - Experienced User
You can contact support via my.netgear.com, and ask for per-incident support.
