IseWise
Sep 28, 2014Aspirant
ReadyNAS Ultra 4 is slowing down my entire network LAN & WAN
Ive owned a ReadyNAS Ultra 4+ for several years now, with little to no problems, however I'm now having a very strange issue. Every time my NAS is connected to the network, the entire network begi...
Sep 29, 2014Guru - Experienced User
Can you try using the blocking controls in the R7000 to prevent any internet access for the NAS? Go into the "Advanced" tab of the router and choose "security", then "Block Services" Add a new service, specifying "ALL" in the pulldown and the NAS IP address. Set the schedule to "always", and then reboot the router. See if the performance symptoms change. I don't think this will impact local NAS access (though I haven't tried it either).
Don't block all IP addresses, just the NAS.
