IseWise
Sep 28, 2014Aspirant
ReadyNAS Ultra 4 is slowing down my entire network LAN & WAN
Ive owned a ReadyNAS Ultra 4+ for several years now, with little to no problems, however I'm now having a very strange issue. Every time my NAS is connected to the network, the entire network begi...
mdgm-ntgr
Sep 29, 2014NETGEAR Employee Retired
Do you forward ports from the web to your NAS? If you don't need to forward ports you shouldn't.
What version of RAIDiator are you running?
The solution would be to backup your data, do a factory default (wipes all data, settings, everything), update to 4.2.27 beta (addresses ShellShock), then put your data back on.
