IseWise
Sep 28, 2014Aspirant
ReadyNAS Ultra 4 is slowing down my entire network LAN & WAN
Ive owned a ReadyNAS Ultra 4+ for several years now, with little to no problems, however I'm now having a very strange issue. Every time my NAS is connected to the network, the entire network begi...
IseWise
Sep 29, 2014Aspirant
mdgm wrote: Do you forward ports from the web to your NAS? If you don't need to forward ports you shouldn't.
I don't forward any ports explicitly to the NAS. I have Upnp enabled on my router howerver.
mdgm wrote: What version of RAIDiator are you running?
4.2.26
mdgm wrote: The solution would be to backup your data, do a factory default (wipes all data, settings, everything), update to 4.2.27 beta (addresses ShellShock), then put your data back on.
Ill have to prepare for that. Right now the instruction StephenB provided is working for me. Is there another way perhaps other than fully wiping it to fix the hack?
