IseWise
Sep 28, 2014Aspirant
ReadyNAS Ultra 4 is slowing down my entire network LAN & WAN
Ive owned a ReadyNAS Ultra 4+ for several years now, with little to no problems, however I'm now having a very strange issue. Every time my NAS is connected to the network, the entire network begi...
Sep 30, 2014Guru - Experienced User
That's useful to know.
FiremedicJM wrote: OS reinstall does not work, Hack remains active after doing this from the boot menu.
So zeroing the gateway mask to ensure the NAS never connects through the router, backing up the data, and a factory reset/data restore is the way forward. As I mentioned, I'd zero the drives before the reset, just in case a rootkit of some sort was installed.
